Go Back   Android Central Forums > Android Chat > General Help and How To
General Help and How To Have a question about how Android works? Can't find the setting you're looking for? Just have a general question about how to get something done? Here's the place!
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 02-06-2010, 04:53 AM
Android Nanite
danc is infamous around these parts
Question Any microusb charger will work right?
Just a quick - probably obvious - question but I thought I'd better check.
I'm going to order a nexus one and the UK/region specific adaptor seemsa little overpriced. I can buy a microUSB charger from amazon (advertised to be compatible with blackberrys or several other devices) for a few pounds including delivery and there's no reason it won't work on the nexus one is there?
Also, as the player comes with a microUSB cable - I can just charge it using that plugged in to my computer or a wall plug with a USB adaptor right?
Thanks again for the help
Dan
  #2 (permalink)
Old 02-06-2010, 08:06 AM
Android Beginner
raremage is infamous around these parts
Default
You have to make sure the output of the charger is right, otherwise you could damage your phone.
If you're referring just to the cable, then yes, any microUSB to USB cable could be used if you are charging via a computer USB port.
  #3 (permalink)
Old 02-06-2010, 09:39 AM
Moto1907's Avatar
Android Beginner
Moto1907 is infamous around these parts
Default
Yes. Any micro USB charger will work but as stated you need to make sure that you don't get one that has a very high output. Look at the output mA. I'm using one from my BB that has a slightly higher output than the stock one but works just fine. If you stay in the 400-530mA range you will be fine. I haven't tested one above this but I wouldn't recommend it as it may over heat the device and I'm not exactly sure how the software handles the incoming amperage. Any USB cable will work but not all are the same. With car chargers, I recommend a factory one(there isn't one right now) or one of equal quality. The reason is thy the cheap ones often short out inside and blow fuses in your car. A good one is a BB Storm factory car charger. I personally use a USB adapter so I always have my data cable with me. USB does charge at a slower rate. Around 350mA. So keep that in mind.
  #4 (permalink)
Old 02-06-2010, 09:45 AM
Cory Streater's Avatar
Moderator
Cory Streater has a spectacular aura aboutCory Streater has a spectacular aura aboutCory Streater has a spectacular aura about
Default
Moving this to the General Help & How-to Forum, as this is good info for all phones, not just the N1.
__________________
Posting Guidelines
Buzz Me
  #5 (permalink)
Old 02-06-2010, 12:32 PM
Android Newbie
mo-bile is infamous around these parts
Default
I have a similar question. I've been using this car charger adapter with my iPhone. It allows a USB cable to be attached to it and then the other end in to the iPhone. Can I just use the usb cable that comes with the N1, plug the usb end in to the car charger and the other in to the N1 and safely charge the N1 in the car?
__________________
Google Nexus One | iPhone 3GS
  #6 (permalink)
Old 02-06-2010, 12:56 PM
Moderator
Default
Quote:
Originally Posted by mo-bile View Post
I Can I just use the usb cable that comes with the N1, plug the usb end in to the car charger and the other in to the N1 and safely charge the N1 in the car?
Yes you can.
__________________
Posting Guidelines
Buzz Me
  #7 (permalink)
Old 02-06-2010, 01:37 PM
Moto1907's Avatar
Android Beginner
Default
As Cory said, yes. This is how I charge bothy iPhone and N1.
  #8 (permalink)
Old 02-06-2010, 03:55 PM
Android Nanite
Default
Cheers, for the quick and helpful responses.
I got this from the HTC website:
AC Adapter Voltage range/frequency: 100 ~ 240 V AC, 50/60 Hz
DC output: 5V and 1A
Which exactly matches the specification for a USB charger I already have for my MP3 player so all is good
Dan
  #9 (permalink)
Old 02-08-2010, 03:19 PM
Android Beginner
takeshi is on a distinguished road
Default
Quote:
It's certainly safe but it's going to charge slowly. I'd suggest getting something closer to 1A (especially given the specs in the post right before mine). The device will pull what it needs.
  #10 (permalink)
Old 02-08-2010, 04:01 PM
rufflez's Avatar
Android Intermediate
rufflez is on a distinguished road
Default
Ive noticed when charging on my computer (macbook), I'd likely kill the computer battery before the phone charges. Wall charging is nice and snappy (about an hour on the Hero).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Creating smartphone communities
Android Central - Android reviews, news and forums Crackberry - Blackberry news, reviews and community TiPb - iPhone news, accessory reviews & forums
Pre Central - Palm Pre Review, News and Community Treo Central - Treo & Centro News and Forums WMExperts - Windows Mobile Reviews & News
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
